04 polaris predator 500 start/charging issues
Old Apr 2, 2021 | 08:27 PM
Barry Ross's Avatar
Default 04 polaris predator 500 start/charging issues
04 predator. Not charging and dies when I turn lights on . Had a couple wires in bad shape. So cleaned up all ground connects. Fixed any crappy connections. Changed both 20a fuses . . First problem started at the on/off. Start. Hi/lo switch replaced it with new oem. Can start it by crossing soloniod. No power to start switch and dies when lights turn on.
Old Apr 4, 2021 | 11:11 PM
Yooper265's Avatar
Is the solenoid clicking when you try to start it ?
Old Apr 5, 2021 | 06:27 PM
Barry Ross's Avatar
Yes it clicks when I test it it was the same as the one I took off had to change the pig tail. I have power going to it I can get it started with booster pack and jumping the soloniod. But if I hit the lights it dies..
Old Apr 5, 2021 | 06:28 PM
Barry Ross's Avatar
Would a bad battery cause this
Old Apr 20, 2021 | 06:24 PM
Barry Ross's Avatar
I put new stator and rectifier and a new cdi box. But coming off the rectifier there's two plugs one with 3 yellow to the stator. But pre owned and last Owner chopped plug off that the 2 red and the 2 black go to is there any spot 2 splice them into
Old Apr 20, 2021 | 08:37 PM
Yooper265's Avatar
The black and red can go right to the battery if you can't find where they go on the harness . red - positive , black - negative
Barry Ross
Apr 2, 2021 08:26 PM
Matt2910
Dec 29, 2019 04:06 AM
Scott Chubbs
Jun 6, 2018 06:43 PM
Peet704
Technical and How-To Articles
Apr 28, 2017 02:47 PM
dn7191
May 8, 2009 06:03 PM
