KLF 300 electrical spark fault
Old Apr 9, 2021 | 06:33 AM
Mark604's Avatar
Default KLF 300 electrical spark fault
Hi all,
never come across this before but my klf300 won’t run and seems to have a constant spark all the time when turning over but no spark at all when the battery is connected?????
all wiring is all ok
Old Apr 11, 2021 | 03:01 AM
KLF300 models are unusual in having 1980s car style ignition. So pos feed from ignition switch to a 12v coil and "ignitor" box and a pickup coil next to flywheel, when the ignitor gets a signal from pickup coil, it sends a neg pulse to 12v coil, just like the old contact breaker points system.
Old Apr 11, 2021 | 03:28 AM
Mark604's Avatar
Default Video to view
hi, mine is a 2000 model and has a CDI, pickup coil , heater control plus relay all within the loom. One of the wires goes through the heater control unit to the coil. It is factory wired so not something someone has ad-hock changed ..... do you think it will be the CDI
Old Apr 12, 2021 | 03:11 AM
Just checked the 2000 parts list and it has an ignitor not a CDI, as they look similar I don't see how you would know that it has a CDI. Also what does the "heater" heat?
Rod Chiodini
Jan 26, 2022 05:19 PM
dgracing318
Jul 16, 2009 04:22 PM
breck
Apr 25, 2008 07:23 PM
Powercat400
Nov 16, 2004 09:12 AM
