05 TRX 400EX won’t start.
Old Aug 24, 2021 | 08:02 PM
AzHonda's Avatar
Default 05 TRX 400EX won’t start.
Have a couple of trx 400s that I got from an uncle who said they may need work since they’ve been sitting. Initially won’t start. Replaced battery, changed oil, flushed fuel tank and cleaned valve, replaced spark plug and this thing still won’t start.
it cranks like it wants to start but I can’t get it to actually fire over.
any ideas? All help is appreciated
Old Aug 25, 2021 | 01:58 AM
Check compression, less than 90psi and it may be needing a rebuild, but rings can stick with standing, so a little oil down the plug hole to lube them and help seal, for initial start, could be all it needs. However too much oil could foul the plug. A hand held for a second over the carb bellmouth can pull the fuel through, but again, too much will wet the plug.
iosifvoyku
Nov 21, 2012 08:36 PM
kyle99
Jun 1, 2008 08:34 PM
Quadaholic127
Apr 4, 2007 02:24 AM
FishinSpot
Jun 20, 2005 04:45 PM
