Honda ATC 200S Project
Old Sep 21, 2021 | 12:45 PM
Rocket-Scientist_1's Avatar
Default Honda ATC 200S Project
Hi All,
I just picked up a 1984 200s. Pretty clean but would like to get a service or repair manual for it. Does anyone know where I can download one?
Thanks!
Brian
Old Jan 23, 2024 | 01:33 PM
Nic317's Avatar
Default Honda atc 200s won’t start
Hey i got a honda atc 200s. I redid the top end 2 year ago and all the timing and its was running well. I have not touched it since winter and its does not want to start, i cleaned the carb and its has spark. I dont think the timing would have changed just by sitting there? Thanks for the help
Old Jan 23, 2024 | 02:57 PM
Originally Posted by Rocket-Scientist_1
Hi All,
Thanks!
Brian
Shoot me your email over PM - I will hook you up!
Old Jan 24, 2024 | 03:38 AM
"Hey i got a honda atc 200s. I redid the top end 2 year ago and all the timing and its was running well. I have not touched it since winter and its does not want to start, i cleaned the carb and its has spark. I dont think the timing would have changed just by sitting there? Thanks for the help"
Remove the plug, put a couple of squirts of engine oil, from an oil can, down the plug hole. Fit a clean dry plug and try to start the engine. After a lay up, piston rings get sticky and compression may drop. A film of oil round the piston seals it and ups compression. A clean dry plug ensures the best spark possible. Another possibility is a sticky valve, if clearance has suddenly increased, a valve may be stuck slightly open.
Old Jan 25, 2024 | 03:15 PM
Nic317's Avatar
I did everything you said and it doesn’t start, i took the cover of and both valve open when i turn the engine..
Old Jan 25, 2024 | 04:07 PM
Nic317's Avatar
Default Honda atc200s
There is some rust on the piston from sitting outside without a spark plug but i changed the oil and squirt some oil in the cylinder
Old Jan 26, 2024 | 04:18 AM
Water getting in through the plug hole is fairly bad for the engine. Do a compression test. Much below 90psi and engines get bad to start. Clean the trigger coil in the case on the end of the camshaft, that engine is prone to poor sparks due to rust in there. As it has stood outside, check for water in the carb.
Old Apr 9, 2024 | 05:14 PM
Nic317's Avatar
I change the piston for a new one and i only got 30psi with new piston and ring,
Old Apr 10, 2024 | 02:30 AM
When you take the cylinder off you need to check everything, bore for wear, and hone it if it is OK, valves for pitted seats, and grind them in anyway. Cylinder head and cylinder faces for signs of a blown gasket. Cam for wear on the lobes. Did you check the top ring end gap before fitting it to the new piston? After the rebuild, double check valve timing and clearances.
choof
May 8, 2010 10:28 PM
meneermalik
ATC 3-Wheelers
Apr 26, 2008 09:53 AM
brentzky
ATC 3-Wheelers
Apr 25, 2007 01:48 AM
kish
ATC 3-Wheelers
Apr 12, 2005 06:58 PM
