2002 Honda 450s foreman shifting problems
Old Sep 26, 2021 | 02:08 PM
Pipeliner79's Avatar
Default 2002 Honda 450s foreman shifting problems
I have a 2002 Honda 450 Foreman foot shift model. I am having trouble with it wanting to up shift hard and down shift hard. Its always had honda atv oil in it. Never have had the clutch to slip or anything. My problem is that the clutch adjustment screw has no effect what so ever on the clutch. I can back it all the way out or run it all the way in and it shifts the same. No slippage in any direction. What could my problem be. Any help appreciated
Old Sep 27, 2021 | 02:23 AM
Well there is something wrong with the adjuster, so probably best to remove the clutch cover and find out what. Get the bike clean, then switch fuel tap off and lift the front vertically until it is sat on its backside. Remove front wheels and any plastics in the way, then remove clutch cover, watch out for the washer on the end of the shift shaft dropping off as you lift the cover off, it has a habit of sticking to the cover, then letting go as you slide the cover out. While in there check the star wheel is tight on the end of the shift drum and the ratchet and pawl mechanism isn't cracked. Fix the adjuster and adjust it properly once the case is back on.
Tfreed
Feb 8, 2021 05:17 AM
farmer john
Jan 17, 2017 02:56 AM
Boff
Jun 26, 2014 10:09 AM
200es
Jan 17, 2012 09:36 PM
rdg
Jan 19, 2005 09:42 AM
