2004 Rancher won’t start
Old Oct 22, 2021 | 07:40 PM
Cferron's Avatar
Default 2004 Rancher won’t start
The four wheeler will crank over but won’t start with choke or throttle but will start with stater fluid. Once it starts with starter fluid if I give it a little bit of chime or gas it will immediately bog then die. Any suggestions?
Old Oct 23, 2021 | 02:50 AM
Clean the carb out. If that doesn't work check compression, should be over 90psi. They fire at lower compression on easy start.
1) Engine problems..
Dec 11, 2018 07:58 PM
Anniegeorge
Aug 23, 2013 10:15 PM
mikes08jk
Sep 30, 2010 04:23 PM
rallyd69
Dec 3, 2007 01:45 PM
