Dies when engaged in gear
Old Oct 31, 2021 | 04:17 PM
Jerry_F.'s Avatar
Default Dies when engaged in gear
My 2004 360 Prairie, has 4x4 and runs fine. When you put it in gear, it dies. The rear end and gear work properly, it think its the clutch, by not sure.
Old Nov 1, 2021 | 03:25 AM
Firstly is the idle speed low enough? As revs have to drop low enough for the front pulley sheaves to move apart enough for the belt to slip. If you think the idle speed is OK, because of variations in belt width and length, Kawasaki put shims on the sheaves, so if the belt is a bit short or wide you can shim it, so it does slip at idle.
Old Nov 4, 2021 | 07:53 AM
Lookfortony's Avatar
Agree with the above. My 2005 had this problem when I had the idle set too high. Lowered the idle and it would stall a lot, but run fine. Had to do the valve adjustment to get it right.
So if you have it idled up so that it doesn't stall, start by adjusting your valves or cleaning your carb, then get the idle down and you should be okay. That being said, I have very, very little experience. Just what's stated above. Pretty much anyone knows more than me, but I hope this is helpful.
rsal452
May 24, 2008 10:25 PM
ssfull
Feb 23, 2006 01:20 AM
mojave13
Jun 28, 2001 12:02 PM
