2001 400 foreman 4x4 fan control
Old Nov 14, 2021 | 02:06 PM
An_Ewok's Avatar
Default 2001 400 foreman 4x4 fan control
my fan has never turned on and new fan control units are a bit pricey anyone got the steps or which wires i need to connect to a switch so i can just do it manually?
Old Nov 15, 2021 | 02:32 AM
The temperature sender unit is near your heel. This shorts to earth when hot enough. So put a switch between earth and this blue wire to turn the fan on manually. If the fan doesn't come on when you short this wire to earth, there is something wrong with the fan control unit. If so, you could disconnect the white/black and pale blue from the control unit and put the switch between these wires. Note, when the fan is on, the blue is an earth and pale blue a live, so don't mix them up.
SOLOLUCKY
Oct 4, 2020 08:59 PM
Honda123*
May 27, 2010 03:20 PM
TLC
Sep 3, 2009 10:58 PM
pete/ny
May 26, 2000 11:33 PM
