1985 250sx
Old Jan 11, 2022 | 12:12 PM
nyckwinter's Avatar
Default 1985 250sx
hello i have a 250sx getting hard to start in the cold, changed the plug and cleaned the carb and didn't seem to do much work, the spark plug seems to be cover in a lot of carbon, can one point me in the right direction ? thanks
Old Jan 12, 2022 | 03:18 AM
Make sure the choke works properly. Could be worth checking valve clearances and compression. If compression is below 90psi after valves have been set, it may be time to check for ring and bore wear, especially if it uses a bit of oil.
Old Jan 12, 2022 | 05:49 AM
nyckwinter's Avatar
thank you sir this should help
340dart
Sep 4, 2015 05:07 PM
yoyo0102
ATC 3-Wheelers
Apr 7, 2007 07:03 PM
Medicineman1171
ATC 3-Wheelers
Nov 25, 2004 06:49 PM
tomkat510
ATC 3-Wheelers
Jul 27, 2004 04:57 PM
200bigred
ATC 3-Wheelers
Nov 4, 2000 06:16 AM
