Linhai digital speedometer diagram
Old Jan 12, 2022 | 06:52 AM
focus6666's Avatar
Default Linhai digital speedometer diagram
Hi guys, I own a Beyond-Linhai 260 ATV model with an analog speedometer which is faulty, and now I want to install a new -digital model.
Does anyone has a schematic or pinout diagram for this model, it has a green connector with 9 pins, the red one is 2 pin ( positive and negative) and the third one is the speed signal.
The green 9 pin connector is the one I need to connect in order to have all signals on the dashboard.
I need to connect 4 indicator lights on the speedometer ( N, Headlights, Indicator lights and R).
I don't have fuel tank sensor or 2wd/4wd switch so I am guessing some of the wires will not be connected at all.
Best regards
Old Jan 13, 2022 | 06:14 AM
focus6666's Avatar
I was unable to find anything on the internet regarding the correct pinout for this Linhai display but I managed to identify all 9 pins on this speedometer by myself, so I will share it here if anyone else needs this.
Green 9 pin connector
Wire color Positive / Negative
Orange + Indicator lights
Light Blue + Indicator lights
Blue + Headlights
Purple + R position
White/Green + N position
Brown/White + 2wd/4wd switch
Yellow/White Fuel tank sensor - connected to Ground will show full tank.
Green/Purple. Water temperature sensor
Blue/Yellow RPM
Red 2 pin connector
Green - Negative ground
Black - Positive
Old Jun 20, 2022 | 11:02 AM
midmarr's Avatar
Hello!
Thanks for publishing your findings- I also have a model that has (used to have) an analog speedometer, I received the digital one you posted aswell, but I don't know where to get the actual speed input (I believe it to be the 3 pin connected) does it require a cable, and where to install it?
Kind regards,
Martijn
Old Jun 20, 2022 | 02:28 PM
focus6666's Avatar
yes it is 3 pin metal connector, the actual sensor should be on the rear wheel and cable goes to the front to the dashboard.
Old Oct 4, 2022 | 02:57 AM
Pboxall's Avatar
Default Speedometer dead
Hope some can he me oit here I pull my 300 linhai out yesterday a short distance and stopped in for a few hours and when I went back I had no led speedometer but did have power to lights and fan very strange fan anyone give me any ideas?
Old Oct 5, 2022 | 02:21 AM
If everything on speedo is dead, it may be one of the main wires to it, probably earth as, if the purple went, only the reverse indicator would have failed, etc. Alternatively the circuit board inside the speedo could have failed.
Old Oct 5, 2022 | 03:16 AM
Pboxall's Avatar
many thanks
chikester
Nov 12, 2008 06:44 PM
markss396
Mar 20, 2008 07:30 AM
nashwaak1
May 22, 2006 11:10 AM
Ladrhog
Apr 24, 2003 10:50 PM
Loyal
Jun 27, 2000 06:54 AM
