Taotao 125 atk cant get out of low gear
Old Jan 21, 2022 | 01:20 AM
Jay_Help's Avatar
Default Taotao 125 atk cant get out of low gear
So if you look up the taotao 125 atk it has a semi manual transmission a manual with no clutch but it is just stuck in low gear I think because it only displays a L in the gear indicator
Old Jan 21, 2022 | 03:07 AM
A bike needs to be moving to change gear, or the engine does. In your other post you can't get the starter working, you won't if it isn't in neutral. Rock the bike backwards and forwards while using the gear pedal. If it still won't change, the selector mechanism will need to be checked for faults.
Old Jan 21, 2022 | 11:00 AM
Jay_Help's Avatar
it shifts in to neutral reverse and Low gear only it’s supposed to be a 3 speed semi manual and shift into all the other gears fine
Porz0011
Sep 7, 2021 02:02 AM
Robbygee
1) Engine problems..
Jul 23, 2017 01:53 PM
rshep
Apr 12, 2015 03:05 PM
keithert
Mar 12, 2013 10:42 AM
point29
Mar 28, 2011 03:46 PM
