2004 Polaris Predator 500cc Won't Crank
Old Mar 5, 2022 | 07:34 PM
conrad1861's Avatar
Default 2004 Polaris Predator 500cc Won't Crank
Edit: Resolution was replacing the battery, solenoid, and starter.
Hello all, I have a 2004 Polaris Predator 500cc that will not Crank. I rode it a few weeks back then attempted to ride it 2 days later. When I did it clicked like the battery was dead. I thought no problem ill charge it. When I got it connected to the battery charger it showed it already had 12v but i left it on until the charger showed it was full. I let it sit for a day then checked with my multimeter and it showed 12v. I connected it back up and now when I turn the key on I do get a neutral light and have verified the switch is set to run but nothing happens but the neutral dimming. I tried bypassing the solenoid it still doesn't crank. I thought it was my solenoid since I didn't get any voltage on the solenoid (verified the side connected to the battery does show 12v) when pressing the start. I do hear the solenoid click when I press the start. I have replaced the starter and solenoid at this time. Next up I will be replacing the battery.
Mauler5
Oct 9, 2020 03:56 PM
380lawrence@gmail.com
May 10, 2016 05:25 PM
starblaze
1) Engine problems..
May 17, 2012 06:34 PM
michele3829
Apr 13, 2010 07:52 PM
warrior405
Mar 10, 2009 11:10 PM
