2005 honda rancher oil leak
Old May 11, 2022 | 02:37 PM
banditman's Avatar
Cool 2005 honda rancher oil leak
2005 honda rancher 350 is leaking oil out the back of the engine on the drive shaft side. Has anyone had this happen before? How do i fix?
Old May 11, 2022 | 07:35 PM
papa hogg scoot's Avatar
Loved
Community Favorite
The best I can remember the crankshaft is 2 half an honda had some 2004late model and all of 2005 had an recalled on crankshaft being out of round [1 halfs didnt get trued] but that campaige is over so the way to I,D that problem would to remove rear recoil[rope start ] assemble an take plug wire off of spark plug[so engine wont start]and eye ball the back of engine[cranking bell for recoil] while using electic start to see if crank bell wobble or looks out of round also have had rear pto[driveshaft]output seal go bad an leak
Old May 12, 2022 | 01:51 AM
If the rear output shaft oil seal is leaking, the rubber boot between engine and swinging arm will have a lot of oil in it. If this seal is leaking, remove swinging arm assembly and you can get at the seal to change it. If memory serves, there is a spring ring circlip to remove, then the old seal has to be pried out. I use a self tapper screwed partly in, then pry on the screw head to pull it out. Care is needed when fitting the new seal, as it is particularly prone to the lip catching on the shaft and turning back on itself.
Old May 20, 2022 | 01:20 PM
banditman's Avatar
what size of tool do i need to get that lock nut on the swing arm off?
Old May 20, 2022 | 07:03 PM
Loved
Community Favorite
17mm hex socket or get 17mm headed bolt and nut an weld together make an one time use socket
Old May 20, 2022 | 07:05 PM
banditman's Avatar
what size is that lock nut thing?
Old May 21, 2022 | 02:06 AM
You can get special castellated sockets from Honda or eBay. https://www.ebay.co.uk/itm/121771935...3ABFBM_PDe1pxg I have used an old socket with castellations ground into it ever since I started on Quads 15 years ago. They are always tight and I have had to use a 3ft long bar to shift the allen screws, plus heat, as even the 1/2" air wrench hasn't been up to it.
Old May 24, 2022 | 07:02 PM
banditman's Avatar
Finally had time to finish pulling the swing arm but now how do i get that seal out that is leaking on the back of the engine on the rear output shaft?
Old May 24, 2022 | 09:29 PM
banditman's Avatar
Anybody know what the part number is on that rear output seal i cant find it on any parts diagram
Old May 25, 2022 | 02:11 AM
Regarding getting the seal out, read my first post (3) above. As for the part number, fairly sure it is 91203-HN7-003
