What's wrong with this motor?
Old May 25, 2022 | 04:26 PM
djshad1469's Avatar
Default What's wrong with this motor?
When you crank the motor with no plug, carb or exhaust it sounds fine. I try to check compression and it sounds like something is smashing around inside and the flywheel looks like it stops turning. I tried uploading a video, but it says it isn't an acceptable type? Gonna end up pulling it apart just want to know what I'm looking for.
Old May 26, 2022 | 02:56 AM
On most ATVs the starter motor drives a one way clutch behind the flywheel. If this slips, the starter doesn't turn the engine and it can make quite a noise.
Old May 26, 2022 | 06:41 AM
djshad1469's Avatar
How do I replace the one way clutch? Is it just remove flywheel and it's behind or do I have to go in from the other side of motor? Thanks
Old May 27, 2022 | 01:51 AM
On any I have come across you remove the flywheel and it either comes off with it, or is left sat on the crankshaft behind the flywheel. Some have gear teeth round the outside which mesh with the starter gears, some have a chain to starter, which, of course, has to come off before the one way clutch can be removed.
Old Jun 9, 2022 | 04:18 PM
djshad1469's Avatar
Thanks to Merryman for nailing this one. I ended up just swapping a flywheel/one way clutch assembly from a parts motor and everything is working perfectly now.
pdizzo
Nov 30, 2006 01:21 AM
tijoe
Oct 16, 2004 09:56 PM
raptorracing
Nov 13, 2003 05:25 PM
ANNIHILATER
Jul 21, 2003 10:40 PM
