Polaris Sportsman 500EFI no start
Old Jun 3, 2022 | 04:12 PM
bob54's Avatar
Default Polaris Sportsman 500EFI no start
Default Fuel pump is working, injector test good and you can see it spray fuel. TPS and MAP test good has spark. Will crank but will not start unless you spray fuel into the throttle body. The injector is spraying fuel and I do not see any restriction to the cylinder with the injector removed. I am not able to do the flash code test because the cluster does not work. and haven't found a way to test the MAP sensor. I tested all the components per the service manual. I don't understand that if the injector is spraying why it will only start if you spray fuel into the throttle body. Anyone have any ideas?
bob54
Jun 3, 2022 03:09 PM
melby180
Dec 15, 2017 08:43 AM
Stephen Sallows
Ask the Editor
Nov 26, 2016 09:44 AM
jamescr
Jul 13, 2010 09:23 AM
Kellen
Jan 16, 2001 01:04 PM
