No power in first gear
Old Jul 16, 2022 | 02:15 AM
KawasakiRider767's Avatar
Default No power in first gear
I have a 1993 kawasaki mojave and I have had this problem for a while and now decided to fix it now. When riding in first gear the quad barely moves, but when you open the throttle all the way the power will kick in. I usually have to cruise around in 2nd gear because 1st gear has no power unless you're reving the engine to the max. I think it's a jetting issue but I would like some others opinions before I try anything. I'll put a video link so you can see
https://streamable.com/74m5zg
Old Jul 17, 2022 | 02:24 AM
Which gear you are in shouldn't alter how the bike runs regarding carburation. It does sound to have a stutter at low revs, probably indicating a weak mixture on slow running jet, and that is usually dirt in the jet. If, once you have cleaned the jets and passageways in the carb out and got rid of that stutter, you are still finding a difference depending on which gear you are in, this often comes down to a clutch problem.
Old Jul 17, 2022 | 03:01 AM
I have cleaned the carb and still have this issue. It's most likely the clutch, I bought it second hand and don't know it the previous owner ever changed it.
Bamafin
1) Engine problems..
Jan 8, 2015 09:17 AM
ssfull
Feb 23, 2006 01:20 AM
TecateKtx250lover
Aug 28, 2005 01:14 PM
Micky
Mar 17, 2002 10:27 PM
mojave13
Jun 28, 2001 12:02 PM
