1986 Kawasaki bayou 300 2x4 wont start
Old Jul 18, 2022 | 07:55 PM
dylan3214w's Avatar
Exclamation 1986 Kawasaki bayou 300 2x4 wont start
Quad was running okay for a few months after a new starter and solenoid. But would always bog out in top gear, after it bogged out it would start right back up then try to die when you gave it gas in 1st, after a few minutes it would kinda fix itself. Another weird issue it would have is if the gas tank wasn’t above about half way it would die under any load but would idle just fine. But this most recent time I was giving it the beans in 5th and it bogged down, but it hasn’t started since just turns over, got gas and spark, occasional pop if I turn it over for awhile, could this be timing ? Cdi box? Or something else, any suggestions would help me and my buddies are stumped
Old Jul 19, 2022 | 02:01 AM
Clean the carb out. Remove jets and blow them and the holes they came from out with compressed air. Check fuel flow from tank. If that doesn't fix it, check compression. Once you get it running again, check the voltage at the battery with engine running, over 15v and the igniter (CDI) box slow cooks, leading to strange faults. Reason for high voltages would be a faulty voltage regulator.
swill123
Technical and How-To Articles
Mar 5, 2022 10:18 PM
jones27
Apr 3, 2009 01:04 PM
Kodiak04
Feb 14, 2009 05:31 PM
Browninga5
Dec 30, 2008 09:47 AM
weezerocks
Jun 23, 2004 06:20 PM
