2003 400ex with no electrical power
Old Jul 20, 2022 | 08:33 PM
Mcyeeterson824's Avatar
Default 2003 400ex with no electrical power
I was riding it normally and I shut my engine off then when I hit start again the starter started spinning and would not stop. Spun until the battery died, then the battery puffed up and got really hot. I put it away after taking the battery off, and now it has no electrical power at all(No headlights, tail light, neutral light, no power to starter). Replaced the battery and solenoid and the fuses aren't blown. Anyone have a clue what is wrong?
Old Jul 21, 2022 | 01:42 AM
Assuming you tried turning ignition off when the starter "ran on" original problem was the solenoid. Are you sure you put the new battery on the right way round, negative earth, as the wrong way will blow the main fuse. Check the connections onto new battery, solenoid, and earths to frame and engine, are clean and tight. Check the new battery has some power in it, some come dead flat and need charging before use. A remote possibility is the ignition switch gone bad, unlikely as it would be pure coincidence, but I have had two bikes this week which were completely dead, and both turned out to be the switch.
yfm350400ex
Jul 18, 2021 02:00 AM
Hatewiring03
Jan 15, 2017 02:19 PM
budmantom
Jun 10, 2009 02:18 PM
101stmp
Oct 14, 2008 08:20 PM
Higgy
Nov 13, 2007 07:15 PM
