Honda recon trx250 has spark and gets gas but only backfires and dosent turn on
The Recon has a design fault. The timing chain tensioner slipper snaps in two, then valve timing slips. Trouble is, you have to remove the clutch cover to check for this, although compression will probably have dropped, if this has happened.
