Hard start after sitting
Old Aug 3, 2022 | 09:32 PM
502atc's Avatar
Default Hard start after sitting
I bought a 110cc taotao atv, wasn’t running. Had no spark and kill switch was cut. Replaced everything spark related and new switch. Has spark now. Finally got it to run and rides around fine but after sitting over night it is really hard to start. Once started and running it’s fine to cut off and restart. Also has new fuel lines, carb, gas tank. (Was rusted from previous owner) thanks for any advice.
Old Aug 4, 2022 | 02:15 AM
Check valve clearance, if valves close up it drops compression and this seems to affect bikes worse when cold. If it is still bad to start cold, do a compression test. Much under 90psi and you need a top end rebuild.
Old Aug 5, 2022 | 12:42 PM
502atc's Avatar
did a compression test it’s building about 110-115 psi
gonna Check valve clearance tomorrow waiting on the adjuster to come in that I ordered.
Will update.
Old Aug 6, 2022 | 01:31 AM
If compression is that good, it won't be valve clearances. Does the choke work properly? Also possible your new carb is set weak, or has got some dirt in it. New tanks and carbs are not always spotless.
Old Aug 7, 2022 | 09:18 PM
502atc's Avatar
took carb back apart and cleaned everything up. Adjusted float . Starts fine .
ATVn
1) Engine problems..
May 15, 2020 08:54 AM
NRA+1
10
Sep 20, 2015 08:47 PM
Zrock
Sep 25, 2013 11:25 AM
Joshwfl
Jul 17, 2006 05:06 PM
cpformula
Sep 4, 2004 12:46 PM
