1986 Honda foreman
Old Oct 5, 2022 | 12:04 PM
Donnie N Veronica's Avatar
Donnie N Veronica
Default 1986 Honda foreman
1986 Honda foreman choke it starts up and runs fine take choke off after a min idles fine go to give it gas it bogs down and dies I’ve ran carburetor cleaner three it and it just had a carburetor kit put on it last year!! Can any body help me with what might be the problem im not a machanic at all
Old Oct 6, 2022 | 02:27 AM
Does it bog down and die if you leave it slightly on choke? If not, then it has a partly blocked jet. When cleaning carbs, I simply remove the float bowl and jets, blow the jets and the holes they came from out with compressed air, check I can see through the jets then put them back, clean out float bowl and refit. If you are getting a lot of dirt through from the tank, put an in line filter between pump and carb to catch the dirt.
04trailblazer250
May 9, 2021 08:00 PM
hondamach10
Jun 16, 2020 10:35 AM
jackrabbit
Oct 28, 2007 10:47 PM
Foremanwww
Jan 18, 2005 01:16 PM
