99 recon runs too high
Old Oct 9, 2022 | 12:22 PM
dmitchellsandlie's Avatar
Unhappy 99 recon runs too high
Hi. New to the form
I have a 1999 Honda recon. I put a new carb on it and put it all back together. I started it and the RPMs are way too high.
I have tried the idling screw. nothing changes. I've tried to adjust the pin in the carb thinking may I hit it wrong or something while putting the spring and throttle cable on. I tried making sure the chock wasn't stuck as well.
My question is: Why is my recon running so high and how can I fix it?
Old Oct 10, 2022 | 02:16 AM
To run high it needs to be getting too much air. Make sure the cable is long enough for the slide to hit the idle speed screw, there are dodgy throttle tops on Chinese knock off carbs, which don't seat the outer cable properly. Check that the O ring between carb and manifold is there and in good condition. A wildly out slow running mixture screw will cause problems, but be sure everything else is perfect before messing with that screw.
Old Jan 22, 2023 | 02:00 AM
aklaki's Avatar
5 Year Member
This fixed my 2012 Honda Rancher TRX420FA. I live 80 miles from my dealer and this saved me the cost of the trip, a rental trailer and the high dealer prices. People that take the time to make videos like yours are a god sent.
snaptube vidmate
muddin2
Jan 29, 2021 08:48 PM
iliveintn
Jul 3, 2003 09:48 PM
mudmagnum
Apr 18, 2001 11:29 PM
RickSoto
Oct 10, 2000 09:46 PM
Recondude
May 23, 2000 12:48 AM
