2005 Honda Rancher 420 ES Shifting to Reverse Issue
Old Nov 15, 2022 | 03:21 PM
INSaluki's Avatar
Default 2005 Honda Rancher 420 ES Shifting to Reverse Issue
My ATV has been having issues shifting down into reverse (using the buttons) from neutral for the past few months. I would say it works 1 out of 8 times. Meanwhile it does not have any issues shifting from gear into neutral prior to me turning off the machine. I'm completely perplexed. I should point out that I am not overly mechanically inclined but would much prefer to try (learn) and fix things myself rather than bring it in. I did search on the forum for a similar issue and there was nothing I could find that was directly related to my issue. It is an electronic shift, which I normally use so I don't typically have to manually click through the gears. I was hoping someone much smarter than I could offer some advice.
Thank you in advance for your time, it is much appreciated.
Old Nov 15, 2022 | 07:03 PM
papa hogg scoot's Avatar
Loved
Community Favorite
May try to adjust or inspect reverse assist cable to see if it working correctly
Old Nov 16, 2022 | 01:57 AM
As papa hog scoot writes, the cable does need to be adjusted correctly, but ES models also have a switch operated by the lever at the other end of that cable, in the back of the gearbox. It earths out when the lever is moved far enough, but I have had quite a few ES models where the switch is faulty, or the wire to it not connected properly. So if adjustment doesn't fix it, check that out
Old Dec 18, 2022 | 03:22 AM
aklaki's Avatar
5 Year Member
Does anyone know if you un hook the shift motor from the front case and it's still plugged into the power plug turn the key on and hit the gear button on the handlebar will the gear move on the shift motor?
Kodi nox
Old Dec 19, 2022 | 03:46 AM
Yes, once, after a few seconds the ECU realizes that no gearchange has happened and goes into fault mode, putting a code up on the dash and refusing to work again until you switch ignition off and back on again. This doesn't prove anything though. If the motor is seized you can check by turning the motor by hand, if brushes are worn down, it may work when out, but not with the load of the shift mechanism on it.
Dobbi
Jul 12, 2020 02:42 AM
jgensur
May 17, 2017 01:53 AM
420Rancher4x4
Apr 14, 2017 02:20 AM
connell
Dec 20, 2010 08:39 AM
jcron
Mar 30, 2008 08:31 PM
