Electrical issue
Old Nov 16, 2022 | 03:54 PM
Donabbo's Avatar
Default Electrical issue
I e got a 2002 Honda Rancher ES. About 15-20 seconds after start up the ignition fuse blows. I e replaced CDI box, coil, ECU. Check carb heater, kill switch connection, ignition switch connection. It seems like a relay but no relays relate to the ignition fuse. Any help is appreciated.
Old Nov 16, 2022 | 06:13 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Did someone put aftermarket carb on atv? if so I have a few that heater was wired backward an would blow ign fuse Try to unplug heter an see if problem goes away
Old Nov 16, 2022 | 06:16 PM
Loved
Community Favorite
Also may want tocheck charging system if over charging the voltage regulator can over charge an cause fuse to blow also can blow cdi and headlight bulbs
Old Mar 22, 2023 | 06:16 AM
aklaki's Avatar
5 Year Member
I love the way you diagnose problems, it is so methodical and thought out. I wish i could be more like you, learnin everyday but not there yet.
snaptube vidmate
Cwallz82
Nov 15, 2022 07:15 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Lolumad273
Sep 24, 2014 06:27 PM
butttch
May 8, 2010 08:03 PM
Scooter650
Feb 10, 2003 11:37 AM
