Fuel Tank Leak
Old Nov 22, 2022 | 03:56 PM
c@tch's Avatar
Default Fuel Tank Leak
Can always smell gas so I thought I would have a look. The 2 lines at bottom of tank looked wet around the fittings that screw into bottom of tank. They came out by hand. Planning on replacing the fuel lines, but are those fittings supposed to have an o ring or something to prevent leaks. I can’t see screwing them back into plastic tank and not leaking.
Old Nov 23, 2022 | 07:26 AM
tiha's Avatar
I am not familiar with what is missing there. Certainly doesn't look like a good setup at all.
Similar to many small engines, like weed eaters, chain saws.
When I come across leaks around fittings like that I use JB weld when installing the fitting. Seems to work well. Basically gluing the fitting to the tank instead of depending on an O-ring, or other mechanical means.
Old Nov 23, 2022 | 04:54 PM
c@tch's Avatar
I will try the JB Weld, it’s been mentioned in some other posts.
Killjoy
May 31, 2015 03:29 PM
sk8er289
Nov 18, 2009 06:40 PM
whaleedited
Sport Quads
Mar 5, 2006 09:54 PM
acfan
Nov 25, 2005 12:20 AM
btolenti
KTM
Sep 13, 2002 03:37 PM
