Chinese atv
Old Jan 11, 2023 | 01:35 PM
Digerjones's Avatar
Default Chinese atv
I've got a 110cc loncin engined quad. The problem is the casting where the starter motor fixes to the casting is broke. How do you get the fly wheel off.. thanks
Dylan
Old Jan 12, 2023 | 02:58 AM
Remove the nut in the centre, either by using an air wrench or a strap wrench round the flywheel. Use the special flywheel puller tool to pull the flywheel off its taper. When refitting, torque that nut correctly as, too slack and the flywheel may loosen off, too tight and it is murder trying to get it off the taper next time.
Old Jan 12, 2023 | 05:11 PM
Digerjones's Avatar
Thanks where would i get the special puller
Old Jan 13, 2023 | 03:27 AM
EBay, or one of the Chinese spares specialists. Care is needed, as there will be several different pullers for flywheels on those Honda Cub clone engines, measure the diameter of the (black) threaded part of the flywheel centre and check if it is right or left hand thread.
Old Jan 13, 2023 | 05:13 PM
Digerjones's Avatar
Thanks
noheartjoo
3) General Discussions..
11
Jun 25, 2016 07:17 PM
May 12, 2016 09:08 AM
scottbrockwell
Ask the Editor
Nov 9, 2015 01:21 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
