Start Issue, No Crank!!! 2003 Polaris Magnum 330
Old Jan 19, 2023 | 05:06 PM
Onehairysalad's Avatar
Default Start Issue, No Crank!!! 2003 Polaris Magnum 330
So I was installing a new battery and was adjusting the wire to secure the it into place, but stupidly left the key in the on position & I kinda sorta made contact on the positive terminal with my pliers. Got a spark & ignition started turning on its own for a few seconds….after this happens, I go to turn over and, nothing. No clicking, not turning over. All other power is working ( headlights, tail light, winch, switches). Did I fry something? I already tested the breaker in the thermal pouch & it’s is great. When I disconnect the breaker, no power works at all! Not too sure where to go from here, please help!
Old Jan 19, 2023 | 10:03 PM
nny's Avatar
nny
Where you resecuring the power wire to the start solenoid or to the battery? From the sounds of it you were securing the wire back onto the solenoid.
Old Jan 20, 2023 | 10:44 AM
Default Polaris Magnum 330
I’m sorry, by “wire” I meant the wire that I’m using to secure the battery, I was twisting it to tighten the battery in place & touched the positive, & from there got an arc & the ignition started to turn on its own, & ever since….silence
Outdoorsguy
Jan 19, 2023 10:10 PM
marcs1969
Dec 19, 2021 06:50 PM
TheRooster822
Nov 9, 2020 09:08 PM
Anotherhunter804
Mar 20, 2009 09:23 AM
