03 Polaris Magnum 4x4 wont engage
Old Feb 28, 2023 | 09:52 AM
vettehigh's Avatar
Question 03 Polaris Magnum 4x4 wont engage
03 Polaris Magnum 330 4x4
The driveshaft is spinning from the engine to front diff, but wheels won't engage
Thank you
Old Mar 28, 2023 | 11:11 AM
Rickey Bobby's Avatar
Default Magnets bad / hib fluid check / front diff needs rebuilt
Hello,
Are you sure there is not a sheared gear in your differential?
Also, check the hub fluid. Good ole Polaris likes to have hub fluid for some odd reason. Google it and you will see what I'm talking about. Make sure it it is filled to the proper level.
Last, check the gaps on your hub magnents. Those hub magnets and the contraption Polaris uses to engage the lock (inside the hub) are very problematic. Refer to a manual for proper clearance of the magnet ring. They are very fineky so be careful.
Mudd
Sep 4, 2023 07:54 PM
yoavb
Mar 22, 2009 07:36 AM
keelam
Sep 28, 2005 11:21 PM
