Solinoid
Old Apr 21, 2023 | 10:12 AM
connorgilbey's Avatar
Default Solinoid
Does anyone know why my quad will start when I put the live from the starter to the battery but when I connect it to the solinoid there’s no sign of life everything electrical has been replaced
Old Apr 22, 2023 | 01:56 AM
When you write "everything electrical has been replaced" I assume this means wiring loom and solenoid but does it include the start button? If there is no click from the solenoid when you press the start button, first check the thin wires to the solenoid, one should be 12v pos and one neg, when you press that start button, check which is not powered and trace it back to find the fault. I use a 12v incandescent test lamp for these tests, as it tests power rather than voltage.
Old Apr 22, 2023 | 02:01 AM
The starter button has been replaced and everything Cdi,stator plate etc I will check those wires now though
dumpmoyers
Apr 2, 2009 12:07 PM
FordFan
Feb 17, 2009 05:37 PM
clancaster23
Aug 7, 2008 03:54 AM
krueger
Technical and How-To Articles
Mar 25, 2008 03:03 PM
