Castle Nut Size
Old May 16, 2023 | 10:08 AM
djshad1469's Avatar
Default Castle Nut Size
Does anyone know the thread/pitch on the rear axle castle nut of a 2002 Recon. Measured it at 20mm but not sure of threads. Thanks
Old May 17, 2023 | 01:56 AM
Probably 1mm pitch. The easy way to check is to take a 6mm dia bolt and lay it alongside the shaft threads. If it is a match, then the thread is 1mm pitch, If it isn't, try an 8mm dia bolt, standard thread on them is 1.25mm pitch.
Old May 19, 2023 | 02:03 AM
I found an old axle shaft yesterday, checked and, as I guessed, 1mm pitch, strange how much coarser a 1mm pitch looks on an M6 bolt, than on the M20 of the axle, but when you put them together they match.
Old May 19, 2023 | 05:59 AM
djshad1469's Avatar
I thought the same thing when I compared them. Got them ordered. Should be back up and going soon. Thanks!
ERBEDS650
Jan 8, 2007 05:18 PM
AtvBlaster
Oct 5, 2006 09:18 AM
mxzxracin
Jan 16, 2006 08:59 PM
insaine
Jun 27, 2004 09:54 PM
GE4x4
Jan 23, 2004 10:35 PM
