2006 Honda recon te electric shift
Old Jun 3, 2023 | 01:35 PM
Smallmechanic's Avatar
Partimemechanic
Default 2006 Honda recon te electric shift
New here guys 2006 Honda recon 250 te electric shift runs good and revs good in neutral but when u shift it in to gear soon as it goes in to gear and neutral light cuts off it kills the bike would anyone have a idea on how to go on finding the problem I have checked all connections and test the charging system I’m little lost right now thanks
Old Jun 3, 2023 | 07:12 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Does clutch make any sounds when enage into gear?
Old Jun 4, 2023 | 02:14 AM
Check for a spark at the plug, in neutral, then in 1st, using the pull start. On most carburettor equipped Hondas there is a wire from the neutral light circuit to the CDI, this gives a better spark in neutral. As it is a negative wire, it is possible the main neg for the CDI is broken, so it only gets a neg, and therefore a spark, in neutral. This is bad for the CDI and could kill it, so check it.
If you are getting a spark in 1st, it could be the centrifugal clutch jammed engaged. Engine off, put in 1st, roll the bike backwards, it should roll freely. Roll forwards and it should try to turn the engine. If it is trying to turn the engine both ways, the clutch is stuck.
tonythom
Jun 3, 2011 08:58 PM
williamN
Dec 24, 2010 07:44 PM
2003 400ex rider 911911
Jun 13, 2009 12:24 AM
ChopperBill
Sep 6, 2000 09:42 PM
