2001 trx 350tm
Old Jun 13, 2023 | 04:51 PM
Spanmymonkey's Avatar
Default 2001 trx 350tm
I have a 01 rancher and I can’t get the neutral light to come on. I have jumped the switch but I only get the reverse light, I changed the bulb, I can crank it over but no spark. Any ideas???
Old Jun 14, 2023 | 02:32 AM
I would guess you jumped the wrong part of the switch if you got the reverse light. Pale green or pale green/red are usually wiring colours for the neutral light on Hondas. When earthed the neutral light comes on. Honda also run this wire into the CDI and to the starter solenoid. It provides a better spark when in neutral, from the CDI, and ensures the solenoid only works in neutral. Either the switch has failed or, if shorting the wire to earth doesn't work, the wire has a break somewhere. There is also a diode in the circuit, can't remember why, this can fail, it is in the fuse box.
Old Jun 19, 2023 | 11:59 AM
So now I got the neutral light, but I still do not have spark
Old Jun 20, 2023 | 01:55 AM
First change the plug, it could be that simple. You next have to run a series of tests on the CDI plug. I can't remember which colour wire does what, but there is a pos feed from ignition switch via kill switch, I think this is black/white. An earth, in fact two (green), the pale green/red from neutral switch, a wire from pulse coil (probably blue/something) which gives an AC pulse and tells the CDI when to spark as the engine spins round, 0.7v minimum but usually about 4v. I think there is a yellow, tapped off from the stator wires, and there will be an output wire from CDI to ignition coil, again AC pulse, to provide the spark. There is also a set of wires for the fan, sheer perversity made Honda wire the fan through the CDI on late 300s and 350s.
Recon250trx
Oct 6, 2021 02:51 AM
santiclean
Technical and How-To Articles
Apr 7, 2008 03:21 PM
olsoncustomfab
Mar 1, 2008 10:57 AM
jpb237
Jan 13, 2008 04:20 PM
renthal15
Dec 5, 2000 09:02 PM
