My 2010 Polaris Phoenix 200 seems to have been hit by Gremlins.
Old Jul 15, 2023 | 07:01 PM
GKofTX's Avatar
Default My 2010 Polaris Phoenix 200 seems to have been hit by Gremlins.
Spoiler
That seem to fix the problem, But, after a while, it went back to the no lights, etc. problem. I tried many different things, and after jiggling the shifter, stomping on the brake, it came on and started right up. I did notice that I did not need to engage the brake, and when the key was on, the brake light was on. After a while, the neutral light would go dim, and the unit would struggle to stay running. Returned to a now start issue.
I'm thinking it might be a bad, or poorly connected, Brake Light Switch. If so, where is the switch located, and how do I test it? There are some "wing nut" adjustment nuts at the rear brakes, and i did turn these before I had these problems. I've since adjusted them back, but nothing changed.
Or, could it be a grounding problem?
Any help with this problem would be appreciated, as the grandkids will be back soon.
Photos of where the Brake Light Switch would help
Thanks
Gramps in HOT Texas.
TDJenkins
Jul 16, 2023 02:19 PM
Scooter250
Apr 1, 2012 01:10 PM
russ2952
1) Engine problems..
Jun 29, 2010 10:22 PM
