2001 Trailblazer 250 starter issues
Old Sep 27, 2023 | 04:17 PM
temartin123's Avatar
Default 2001 Trailblazer 250 starter issues
I have a 2001 Polaris Trailblazer 250 2 cycle. I put in a new starter button and it hasn't been right since as the starter won't work. I feel like all the connectors are making contact at the switch. This is what I know:
- it will start when I pull manually
- the brake light works
- I get 10.68 volts to the small wire on the solenoid when I push the start button up.
- when I short the 2 posts on the solenoid, nothing happens
- the battery is new. I hooked up a jump box to the battery just to make sure it wasn't the battery.
- I checked the fuse and is good
- I cleaned the terminals at the switch
Thinking it is some safety switch issue that is not letting it start. I don't have a wiring diagram. Hoping for some direction. Thanks
bnjoplyr
Mar 10, 2020 12:24 PM
SC_Shooter
Jan 16, 2019 08:20 PM
offner0928
Dec 5, 2014 02:56 PM
red777
May 25, 2009 11:41 PM
Jiu Jitsu77
Nov 27, 2007 06:32 PM
