2007 eton 90 4 stroke
Old Sep 30, 2023 | 07:21 AM
venom290's Avatar
Default 2007 eton 90 4 stroke
Good morning,
Need some info on stator wiring please.
Wires from stator had no connector, not having any luck finding correct diagram.
Came with no plug , not sure wire location
from stator white, yellow, green and 2 separate plugs black/red and blue/white.
from harness yellow/red ,black ,white/red . 2 separate plugs black/white and white
Old Oct 1, 2023 | 03:31 AM
Most Chinese bikes copy Honda wiring colours, which are, blue/white trigger coil to CDI, black/red power coil to CDI, yellow and white wires to rectifier/regulator, green is earth. ETons were different, but if you check where each of the wires come from, you should be able to work it out, admittedly, which should be trigger and which power, at the CDI, may not be easy to tell.
Vegas_guy
Apr 15, 2020 08:33 PM
Thawkins5443
1) Engine problems..
Nov 29, 2011 02:29 PM
warrior-435
May 11, 2010 11:46 AM
shapay
Mar 10, 2010 04:27 PM
