2000 Kawasaki Prairie CDI box
Old Oct 22, 2023 | 04:17 PM
KawasakiDad's Avatar
Default 2000 Kawasaki Prairie CDI box
So my daughter and I are working on a 2000 Kawasaki Prairie 400 4x4. When I purchase this thing it did not have a CDI box. After doing research, I found out that these are very expensive. I found a Chinese brand CDI box for an off brand atv that is a 400 cc
for $40 that looks like the plug is the same. Would this work for my prairie, are there any other CDI boxes that would work, or do I have to bite the bullet and buy a factory CDI box?
Old Oct 23, 2023 | 04:13 AM
It is possible that the one you picture would work as the "off brand atv that is a 400 cc" may be a copy of a Kawasaki, but that black box could also be a standard Chinese CDI and you have no way of telling without the wiring diagram for that bike.If there are 5 wires going to your black box, find the wiring diagram for your bike, find one for a KLF400 Bayou. They have different wiring plugs but the Ignitior is probably the same, as Ignitor is Kawasaki speak for an ignition control module, not a CDI. These work like a 1980s car ignition with a 12v coil, and are powered from the battery, (pos wire to ignition coil from ignition switch). Check on the wiring diagrams if this is the case. Aftermarket ignitors for 400 Bayous are cheap, sort out which wire from your loom goes to which on the Bayou ignitor and connect them.
Old Nov 21, 2024 | 07:16 AM
Sgtsholly87's Avatar
Default Cdi
So did this cheap cdi box work?
Kelly Aschan
Oct 4, 2015 07:50 AM
dgratvbikeshop
Feb 17, 2009 06:10 PM
themudchild
Apr 13, 2005 09:44 PM
bLuRRRR27
Aug 26, 2004 08:16 PM
