95 polaris explorer running issues
Old Jan 29, 2024 | 10:07 PM
Linkjonah8@gmail.coml's Avatar
Default 95 polaris explorer running issues
So I bought a 95 polaris 400 explorer and guy says he just had a top end redone in it and that he was plowing his driveway way and it died I have completely rebuilt carb I have spark I have gotten to back fire real loud few time but never start checked compression with a O'Reilly rental and it says 65psi could valves needing adjusted or timing being off cause this low compression reading?
Old Jan 30, 2024 | 04:05 AM
I don't know that machine at all but the answer is yes. Check valve adjustment is correct and while you have it at TDC on the compression stroke, (check this by the piston as well as the flywheel mark), check the cam timing mark(s) are correct. If timing is out, it must have slipped.
VirginRider
Jul 24, 2020 12:01 PM
Geartec
May 28, 2015 10:55 PM
tim001232
Jul 29, 2008 12:44 AM
jokerswild007
Jun 30, 2008 11:04 PM
GR8Dane
Jul 6, 2004 01:14 PM
