Lifan 200cc running rough
Old Feb 28, 2024 | 01:58 AM
Cubbson's Avatar
Default Lifan 200cc running rough
Hey i recently bought a chinese quad that has a lifan 200cc water cooled engine and i'm having some issues. the wiring harness was shot and i couldn't find an exact replacement with the 3 yellow wires for the stator and 2 for the pickup so i ordered a generic chinese quad harness with stator. the old stator was a 12 pole stator while the new is a 8 pole but they swapped perfectly. i also replaced the carby. now i managed to get it to run and idle but at idle every now and again it sounds like it skips a beat and when i go on throttle it bogs down and dies, i've tried adjusting the carby but it hasn't helped much. any idea on what might cause my issues?
Thanks
Old Feb 28, 2024 | 03:28 AM
Check the charge rate at the battery in case it is simply overcharging due to a faulty regulator, but 200cc engines are quite rare so I doubt if anyone will make a "universal" harness for it, and a stator for a Honda "Cub," "Minarelli" two stoke or GY6 clone, is unlikely to work properly, I'm quite surprised that a stator meant for a different engine would work at all.
DeMarcus Haliburton
Aug 16, 2020 07:52 PM
anthony59
Nov 29, 2017 12:29 AM
mrred85
Nov 11, 2016 12:48 PM
kjt
Jan 17, 2015 05:03 AM
