KLF300 VIN year of manufacture etc
Old Mar 27, 2024 | 04:31 PM
setinomad's Avatar
Default KLF300 VIN year of manufacture etc
Little help pls. The vin on my KLF300 is JKALF300CCB610725. Can someone confirm that this is a 2005 vehicle, and perhaps point me to a link for the most appropriate service manual for this model. Thanks.
Old Mar 28, 2024 | 03:27 AM
There is something wrong with that VIN number. The tenth digit is the year code, and C is for 1982 or 2012 and those dates are before and after the KLF300 was in production. The 2005 code was 5.
Old Mar 28, 2024 | 03:54 AM
setinomad's Avatar
hi merryman :-) thank you ! so I'm not going mad, I'm confused re manufacturing years and the evidence of the vin on the machine. the seller said 2005. perhaps he bashed it enough to have to replace part of the frame. no matter really as I'm happy with the atv; but it makes it a bit difficult re ensuring I get the correct manual tho I guess there may not be a huge amount of difference between models. the vin is clear enough.
Old Mar 28, 2024 | 07:37 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Prairie maybe ? Bayou is KLF VIN Showing Kalf is it automatic? gear change?
Old Mar 28, 2024 | 09:10 AM
setinomad's Avatar
hi there. has a gear lever, 5 gears + rev. I think I'm going to have to take a leap of faith in regards to buying a manual; perhaps the one which has the widest spread of model years, that's the haynes manual I think.
Old Mar 29, 2024 | 04:11 AM
I'm not an expert on them but have mended quite a lot and, from experience, only the model A, very early KLF300s, were "different". Models B & C didn't change all that much to the end of production. The later KLF300s had a different tank sticker, so some idea of age can be got from that. Most manuals can be used to cover the same model, I'm still using a 2000 manual for Honda Recons, newer ones have a different cylinder head and exhaust gas recirculation, plus the electric shift hadn't come out in 2000, but the wiring diagram and engine strip down details like torque settings, are near enough.
Old Mar 29, 2024 | 07:03 AM
setinomad's Avatar
made me smile that you'd put the word "different" in quotes. whether we're talking ATVs, religion, or political persuasion, we have to try not to tread on other people's toes. oooh, see those model A efl300s ! they never try to fit in with the other ATVs. :-)
Old Mar 29, 2024 | 04:29 PM
tiha's Avatar
Well that is interesting. I run it and it comes up as 2012 motorcycle.
You realized it looks like that frame has been modified right there right? Someone welded that VIN over the factory VIN. Replacement frames that I have installed have come with no VIN. You are supposed to transfer from the old machine and stamp your own.
My county auditor gave me this website. I check them all here before I try to register. It helps figure out the ones when you can't read a digit in the VIN. If it won't read here then more than likely you got something wrong. Or someone did in your case.
Search Results for VIN : JKALF300CCB610725 (dot.gov)
Old Mar 29, 2024 | 04:38 PM
tiha's Avatar
From another forum. But I am pretty sure that VIn has nothing to do with that machine. If I was looking to purchase it I would assume it is stolen.
Digits 1,2,3 are World, Manufacturer, Identifier
1 = J ( Japan or whatever country the vehicle is made in )
2 = k ( Kawasaki or Y for Yamaha or S for suzuki etc)
3 = 1 or A ( code for motorcycle )
Digits 4,5,6,7,8 are Vehicle descriptor Section
4 = Vehicle category
C=scooter
B=business model or commuter
N=single cylinder sport/street
G=multiple cylinder sport/street
F=Family
S=Off road
V=V-Type engine, street, V2/V4/v6/v8 etc)
5= Engine displacement
A=49cc and less
B=50-69cc
C=70-79cc
D=80-89cc
E=90-99cc
F=100-124cc
G=125-149cc
H=150-199cc
J=200-249cc
K=250-399cc
M=400-499cc
N=500-599cc
P=600-699cc
R=700-749cc
S=750-849cc
T=850-999cc
U=1000-1099cc
V=1100-1199cc
W=1200-1299cc
Y=1400-1499cc
Z=1500 & up
6= Engine Type
1=2 stroke single
2=2 stroke twin
3=2 stroke triple or four
4=4 stroke single
5=4 stroke twin
6=?
7=4 stroke four
7=Design sequence or model version first version uses 1 then second version uses 2 etc... the tenth version would then be identified by the letter A then B etc..
8=Model version ( base model usually by an A, another letter would be used for special editions or different models of the ame vehicle )
9=Check digit ( 0-9 or X )
10= Year Code
80-A
81-B
82-C
83-D
84-E
85-F
86-G
87-H
88-J
89-K
90-L
91-M
92-N
93-P
94-R
95-S
96-T
97-V
98-W
99-X
00-Y
01-1
02-2
03-3
04-4
05-5
06-6
07-7
08-8
09-9 ( Don't know what happens after that )
11= Factory code ( manufacturer code for what plant it was built in )
12,13,14,15,16,17= Vehicle Identification Number ( serial number )
So for example a 2003 Kawasaki Ninja 500 would look something like this
JKA GM71A X 3 2 123456
JKA= Japan,Kawasaki,Motorcycle
GM71A= Multiple cylinder sport/street, 400-499cc, 4stroke four, Version1, Base model
X= Check digit
3= 2003
2= Plant #2
123456= Serial number
Old Mar 29, 2024 | 04:40 PM
tiha's Avatar
Give us more pictures. From that one pic you posted it looks a lot like my 1996 bayou 300.
Hopefully we can help you find the right manual, like the bayou manual covers like 1989-2006 but knowing what year to look at is important.
Or actually get the manual and you can probably figure it out from there.
