Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Kids Chinese quad identification
Old Apr 11, 2024 | 08:50 AM
Greyrock's Avatar
Default Kids Chinese quad identification
Hello Group, my grandkids received a new Chinese kids quad from a family friend last Christmas, and it came with no paperwork. After 4 months of use, the rear brake caliper is leaking and I need to replace or rebuild it. Not knowing anything about kids quads at all, I don't know where to start looking for parts without a part number, model number, CC size etc. It has the parking/emergency brake option as well. Amazon, fleabay, etc. have parts but I need to make sure it's correct. I've attached the VIN tag and a picture of the ATV to help (pardon the messy shed)
VIN Info
Rear caliper with parking brake
VIN Tag info
Quad picture
rear caliper w/parking brake
If you need the actual VIN number let me know. Thanks
Old Apr 12, 2024 | 02:21 AM
None of your pics have come up. I think you need to have posted a few times before they allow pics.
Give us the VIN but, unless it is one of the big name makers like Kazuma, finding parts is a matter of looking at the on-line pics and measurements and finding the calliper that is identical to yours. Parking brakes that depend on the hydraulic system are a really bad idea, which is why the Japanese makers mostly use cables for the parking brake. If your bike has a hydraulic parking brake, use it as little as possible.
Old Apr 12, 2024 | 05:55 AM
Greyrock's Avatar
Thank You, here is the VIV: L08AGJ2C7M1002206
and the rear caliper itself has a number that get no results on Google
that is: AJ20220928
Hope this helps, Thanks again
Old Apr 13, 2024 | 02:47 AM
I ran it through Cyclepedia's vin decoder and got:-
2021 Apollo 22
1 Cylinder
4 Stroke
Displacement: 125cc
Manufacturing Plant: ZHEJIANG CHINA
The importer does have a website https://www.apolloatv.com/products/commander-125cc/ with email address for parts, that often doesn't mean much but worth a try.
Old Apr 13, 2024 | 08:21 AM
Greyrock's Avatar
Thanks so much! much more than I could find, I have a starting point. Thanks!
Old Nov 9, 2024 | 02:37 AM
mkford0's Avatar
I know this is a few months ago but did you ever find anything for this? I have almost the same quad 2021 Apollo 45 only my PN is AJRD211114A and absolutely nothing shows up for a search on that number. I do have some experience working on quads but this is the first time I have never seen a rear caliper with a hand and foot cable hooked up to it. I am guessing the parking/emergency brake option that was mentioned is the extra cable attached to the caliper that runs to a hand lever. All searches for 125 atv rear brake calipers only have the foot pedal, searching for parking/emergency brake option don't turn anything up either. I'm almost thinking I may just try to find a replacement without the parking/emergency brake option and remove the hand lever.
Old Nov 9, 2024 | 03:05 AM
Have you tried that Apollo website I linked to? Cables, or fluid lines? Callipers with a fluid line for foot brake and a cable for handbrake, are common. The current Honda 420/520 IRS uses one, as did many Yams, from the 1990s onwards.
Old Nov 9, 2024 | 08:19 AM
Greyrock's Avatar
Never found the right caliper with the handbrake option (except at our local purchasing dealer - TOO expensive) so I took the caliper apart and found the piston seal somehow was not seated properly in the seal groove. I lubed it up, re-assembled it and so far, so good. I did find the right pads on Amazon though. Now I'm not sure if it was the original assembly screw-up or from the first few weeks of use, I'll never know. In any event, I know where to get the pads next time. But the caliper, I may just have to suck it up and get it from the dealer, OR go without the handbrake option, those are plentiful all over flea-bay and amazon. Good luck!
Old Nov 10, 2024 | 04:04 AM
mkford0's Avatar
The setup is cable from the hand and fluid from the foot pedal. This post help me with the term for the way it is setup. I was not aware that it was an emergency/parking bake, after I started digging with that term I was able to find a few that looked similar. Unfortunatly most of them did not list full specs so I couldn't match the hole to hole size. What I did is order a cap for the caliper and I plan on just removing the hand cable/lever.
Old May 4, 2026 | 10:06 AM
Tylormcg's Avatar
Default GIO Kids Quad
Hello!
This is my first post on a thread..... I cant seem to find any info on a quad I picked up. The vin is L5KGUMS0691023364. I am wondering if some one can help me out!
Thanks,
Raffertey
Sep 13, 2017 12:24 PM
kritter73
1) Engine problems..
Aug 17, 2013 07:12 PM
Eric1981
Jun 6, 2012 09:24 PM
ktmbk
Sep 12, 2010 12:15 AM
MoparRob
Nov 28, 2005 11:01 AM
