Why do engines backfire?
Old Nov 13, 1999 | 06:29 PM
RyanH.'s Avatar
I always have wondered why engines backfire any reasons? Luckily just my lawnmower does this so far.
Old Nov 13, 1999 | 07:33 PM
mudmachine's Avatar
at what point does it backfire?.. just while running?.. when youre shutting it down?.. under load?.. hot? cold?... usually its improper fuel mixture/incomplete burn.. Sometimes its leaky exhaust valves.. Be more specific....
Old Nov 13, 1999 | 11:55 PM
Tree Farmer's Avatar
Mechanics have told me backfiring usually indicates a fuel-lean fuel-air mixture.
While ATVing, I've noticed backfiring on different machines sometimes when shutting down the throttle, transitioning to idle, maybe while descending a hill under engine compression braking.
These examples of transient backfires while the engine is not under load do not pose serious problems; often, such a backfiring condition can be eliminated by backing out the carburetor idle mixture screw slightly.
Tree Farmer
Old Nov 14, 1999 | 01:40 AM
hardlydangerous's Avatar
Improper Fuel / air mixture Some rev limiters have been the cause .and in the case of most four strokes the timming is off.or dirty points on older machines,AND LAWNMOWERS.....hardlydangerous1@yahoo.com
Old Nov 14, 1999 | 08:34 AM
Jaybee's Avatar
It is probably your throttle. Mine had to be replaced when I bought it just for that reason. jThere is some kind of electronic device in the throttle body that causes miss timing. Call a reputable dealer and he should tell you this. Had mine replaced and it was fine after that.
Jaybee
Old Nov 14, 1999 | 02:32 PM
RyanH.'s Avatar
It only backfires when I shut it off.
Thanks for the replies
COFatboy
May 2, 2020 12:06 AM
manuelrivera
Aug 8, 2015 04:34 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
blpersinger
Jul 15, 2015 09:56 PM
