Rancher 350 engine swap
Old Jun 10, 2024 | 09:30 AM
CJR's Avatar
CJR
Default Rancher 350 engine swap
Looking to put engine out of a 2003 4wd into a 2000 2wd. Question is do I need to make any change on the front cover or will it be ok just to leave the front differential shaft as is and use that way?
Old Jun 11, 2024 | 02:27 AM
You can leave the front shaft as it is. The oil seal is in the case and seals the shaft, so no problems. Going the other way (2WD engine in 4WD bike), would require the shaft through the engine and the clutch case, changing.
Old Jun 11, 2024 | 08:10 AM
CJR's Avatar
CJR
After I got both engines pulled that what I was planning on doing. Sure appreciate the reply verifying what I had decided.
Old Jun 12, 2024 | 01:59 AM
Not sure you "got the message", you don't need to alter the engine to fit it to a 2WD bike.
Old Jun 12, 2024 | 06:01 AM
CJR's Avatar
CJR
Yes I got it. Thank you much
tidwel
Oct 15, 2008 02:53 PM
225yamahadx
Dec 5, 2007 10:35 AM
Harw
Feb 7, 2004 10:45 PM
