2006 sportsman efi ho x2
Old Aug 31, 2024 | 02:05 AM
southerncaddy's Avatar
Exclamation 2006 sportsman efi ho x2
i have a 2006 polaris sportsman 500 ho efi x2 and this atv has been sitting for a few years all because it wasnt charging properly and one day it dies and wont restart, i must note that i wasnt the one riding it so i cannot give much information to what it did other than what i was told. i decided to take it out to try to get it repaired and even though i have battery voltage and voltage at some kind of big black box with 4 bigger gauge wires going to it with a rubber cover over it. i cannot seem to get anything on the cluster nor do i have any headlights, clicks, pops, or any noise indicating life. i have crossed the solenoid with a screwdriver to verify i have enough amperage to turn the engine over but cannot get anything when trying to turn it over by the key. is there any way to bypass the ecm or something to where i can start the bike to make sure it is going to run or what can i do to check as to what is causing me not to get any life when i turn the key on. also i should note that i will need any explanations dumbed down as i really am not good at diagnosing anymore but i have no choice on this particular matter unfortunately. i was told of a ecm recall but i dont even know if this bike is covered or not. i hope this isnt too drawn out but i really need help and i cannot afford to go to a shop at the moment. thanks for any help that yall can give.
Old Sep 7, 2024 | 07:29 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
First you could take the vin# to a dealer or maybe online and find if there is any outstanding recalls for the ecm. if it was a factory recall it should still be covered. there might be an inline fusible link in the main power line that is the issue. check for a black pouch that should cover this link. if it's defective this will cause no power to get through. you said the bike had charging issues? the bike could have a bad stator and regulator that would cause this. you need to first find out the lack of power issue.
tompeter
Nov 2, 2022 02:10 AM
2006sp0rt$
Sep 10, 2022 11:24 AM
Sumbakamike
Dec 21, 2011 04:01 PM
Polaris500Sportsman
Sep 14, 2009 12:33 AM
nettoz
Sep 9, 2008 03:10 PM
