2006 Honda 400ex oil leak at head stud nut.
Old Oct 2, 2024 | 10:54 AM
Sgural84's Avatar
Default 2006 Honda 400ex oil leak at head stud nut.
Looks like when running there is oil coming up from the head stud right in front of the spark plug. I just did a top end rebuild, everything seems to be good except this oil leak... The kit came with new studs an nuts....hard to tell in the photo, but I could watch it come up from the threads between the nut an stud while running. The drip down the front of the head thru the weep holes. Tried tightening a little more like a quater turn but don't want to go to much. Not sure where to go with this
Old Oct 3, 2024 | 02:25 AM
Don't know the model at all but a glance at the parts drawing shows one head nut has a different washer under it to the other three. This usually means the "odd" washer has a seal on it, Dowty or copper as a rule. Torque head bolts to the correct setting, never more, there isn't much margin before you start to strip the aluminium threads and uneven tension can distort the head.
Old Oct 3, 2024 | 05:29 AM
papa hogg scoot's Avatar
Loved
Community Favorite
Honda ATV 2006 OEM Parts Diagram for CYLINDER HEAD | Partzilla.com
Old Oct 3, 2024 | 05:33 AM
Loved
Community Favorite
Like merryman said photo 10 is different than the 3 of photo 11 #10 is a sealing washer the others are plain washers under #10 washer is passage way the oil travels to oil cam and rockers
Old Oct 3, 2024 | 08:53 AM
Sgural84's Avatar
Well I got in contact with bpr which I got the kit thru, they suggested using the original cap but which sealed it up.....so I will keep an eye on it from here on out
01'ds650
Jul 5, 2012 11:48 AM
ikeyrider
Dec 2, 2008 08:53 PM
jusrlax
Mar 3, 2008 12:09 PM
