Something let go at WOT, can't find the issue when rebuilding
Old Oct 14, 2024 | 11:22 AM
SlowSL's Avatar
5 Year Member
Default Something let go at WOT, can't find the issue when rebuilding
A couple years ago I was running my son's 86CC 4-stroke down the road, WOT for a good while. Something suddenly let go and it lost about 30% power, and you could audibly hear a change in the exhaust tone, if I remember right, it got a little louder. I don't remember if it was trying to stall when I let off the throttle, but I think it was being difficult. I was easily able to ride it the rest of the way home and parked it. I noticed a couple drops of oil on the floor, may or may not be related. I forgot about it for a couple years, recently decided to pull it apart and see what happened. The only thing I found was that the intake valve was leaking air when blowing air into the spark plug hole. I adjusted the valve clearance on both valves and that seemed to fix the leaking valve. I disassembled down to the piston, which looked fine, and no slop was found. I put it all back together, waiting on a new carb to try and start it, but I'm sitting here questioning what could have happened and why I found nothing major wrong. Any ideas?
Old Oct 15, 2024 | 03:19 AM
May be a carb issue or, if exhaust did get louder, a baffle turned, partly blocking the exhaust.
Old Jan 8, 2025 | 01:59 PM
SlowSL's Avatar
5 Year Member
Turned out to be a valve issue. There was no clearance, works fine after adjusting them.
Old Jan 9, 2025 | 03:49 AM
They usually get very bad to start when that happens, had one last week with both inlet and exhaust valves closed up.
Old Jan 9, 2025 | 10:13 AM
SlowSL's Avatar
5 Year Member
I still wonder what happened with mine that it did it at WOT, how would the valves smash down and remove the valve clearance like a switch? I was running WOT for quite a while.
boulderboy
Oct 5, 2020 12:36 PM
minihoser
1) Engine problems..
Dec 19, 2011 06:29 PM
GH250
Sep 20, 2010 07:37 PM
servicepcrc
Jan 9, 2008 08:40 PM
MudStud
May 26, 2003 07:38 PM
