2020 450ho says it's overheating but
Old Dec 21, 2024 | 11:30 AM
chuckinnc's Avatar
Default 2020 450ho says it's overheating but
450 says 100c only after 3-5 minutes, the coolant isn't even warm, atleast at the radiator cap, so I am guessing it is either a bad sensor or bad thermostat..Which is a more common problem, only use it for short trips in a open field seversl times a month, so I was thinking of bypassing it or the thermostat but I can\t find either one.
Old Dec 31, 2024 | 11:05 AM
Red64's Avatar
Default 450
What year? It makes a difference. Could possibly be the thermistor in the radiator. Could be a bad thermostat. That’s located on the engine. Could be the impeller on the pump is bad or broken. Do you have flow in the radiator? Do both hoses get hot?
You need to check these things before you throw the parts cannon at it.
Old Jan 25, 2025 | 12:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check to see if all the hoses are evenly hot. if not, then maybe thermostat. I'm assuming there is not an air bubble which usually only happens if you have drained the system.
MapleNeil
Jun 26, 2016 09:11 AM
Kerick
Jun 7, 2009 09:27 AM
700vtwinman
Jul 28, 2005 01:52 PM
anth
Dec 23, 2003 07:27 PM
Raptor660RSC
Jan 27, 2003 02:45 PM
