Which crush washer for Honda Recon oil drain plug?
Old Jan 15, 2025 | 11:09 AM
ricoscoro's Avatar
Default Which crush washer for Honda Recon oil drain plug?
Which oil drain plug crush washer should I be using for my 2002 Honda Recon ES?
Thanks
Old Jan 16, 2025 | 03:40 AM
It is just an aluminium washer. I have never fitted a new one, old washers work fine, they sometimes stick to the sump. Do not overtighten the plug. Honda use a stupid system of casting a slot in the sump threads which reduces the threaded area and wakens it, I have come across many that have been stripped.
Old Jan 16, 2025 | 05:25 PM
ricoscoro's Avatar
any idea on what torque to use on the drain plug?
I thought I saw something about these being crush washers, but I believe when I changed in the past that the washer may be stuck to the bottom.
Old Jan 17, 2025 | 03:35 AM
Haynes manual for 450 gives 18ft/lbs, I always do it by "feel." Being aluminium the washer would crush a bit when new, so theoretically a new washer would be preferable. As I wrote above, I've changed oil on hundreds of Hondas and they don't leak with a used washer.
Old Jan 17, 2025 | 06:08 PM
papa hogg scoot's Avatar
Loved
Community Favorite
I replace washer after every 2 times used when the washer get crushed paper thin it cant crush any more then it will start stripping threads an can crack case just make sure you remove old washer before installing new one the size is 12mm
demps
Apr 8, 2019 05:09 PM
Hawkman300
Aug 11, 2010 09:23 PM
reconman16
Apr 15, 2007 05:20 PM
moto93
Jun 16, 2002 12:59 AM
Jason24
Jan 31, 2001 06:38 PM
