Intermittent fan
Old Feb 25, 2025 | 11:52 AM
Bigmelton's Avatar
Default Intermittent fan
Okay I have a 05 Polaris sportsman 500 HO. I bought it used and when I bought it the previous owner had the radiator fan wired up to a switch. Every time you turn the key on even when it was cold it would flash hot. I replaced the ECM and bought a new radiator fan. The new ECM fixed the hot flash and the old fan would kick on when it got hot. The old fan was really noisy and the bearing seemed shot. When I put the new fan in when it gets up to temperature the fan will barely kick on and off and never fully come on. When I disconnect the temperature sensor on the side of the block it will kick on and off a couple times and then fully come on. Has anybody had this happen before and where do I need to look or what do I need to try to fix this? Thank you for any help.
Old Feb 26, 2025 | 04:47 AM
Red64's Avatar
Default Sensor
Sounds like the actual sensor is bad and not sending the correct signal to the fan.
Tpr430
Jun 2, 2009 08:00 AM
01 SCRAMBLER
Mar 26, 2008 07:15 AM
magals
Sep 6, 2007 10:24 PM
AHAUGHT
Sep 25, 2006 10:46 AM
HALL650
Nov 28, 2001 12:49 AM
