2003 Honda Rubicon 500 issues
Old Jul 5, 2025 | 06:58 AM
trussellk's Avatar
Default 2003 Honda Rubicon 500 issues
Good morning. I recently purchased a 2003 Rubicon 500FA knowing the shift angle sensor might be bad. I replaced the sensor but it still gives me the same issue. The sensor calibrates (or at least it sounds like it does) and then when I start it back up everything looks normal. But, as soon as I put it into gear, the transmission indicator starts flashing again and I only have first gear. Also, I cannot get the machine to go into diagnostic mode to see if there are any codes in they system. Any ideas on what to look for?
Old Jul 5, 2025 | 08:24 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Check the gear switch in rear of engine ohm out each gear position
Old Jul 6, 2025 | 06:13 AM
trussellk's Avatar
thanks for the lead. sure enough, i got waaaaayy too much resistance when its in drive. gonna swap the sensor and hopefully that does it.
Old Jul 21, 2025 | 06:20 AM
Loved
Community Favorite
Any updates?
Old Jul 21, 2025 | 06:29 AM
trussellk's Avatar
As a matter of fact, yes. I was finally able to get to it late last week. Apparently someone had spliced two of the wires together for the transmission position sensor. I'm going to try to attach a picture here so you can see the handiwork that I discovered. I don't understand why someone would do this, but once I replace the sensor, everything worked out just fine. Even gave it a quick test run through the woods this weekend
Old Jul 21, 2025 | 06:37 PM
Loved
Community Favorite
WOW Thats great you found it I am like you dont understand some people....... Ride and enjoy
Old Jul 21, 2025 | 06:55 PM
trussellk's Avatar
Much appreciated the direction on this.
Old Jul 22, 2025 | 06:09 AM
Loved
Community Favorite
Your much welcome
Wally Gator
Jul 23, 2019 04:40 PM
hondaholics
Sep 18, 2012 11:57 PM
pepsiboy
Jun 9, 2003 03:18 PM
dashrat
Apr 7, 2003 10:31 AM
