2013 Honda Recon ES - Engine shut down while driving
Old Oct 4, 2025 | 10:12 AM
HondaMan71's Avatar
Default 2013 Honda Recon ES - Engine shut down while driving
2013 Honda Recon ES - engine shuts off while driving. Went to Honda Service and they were not able to replicate, so they did nothing. Any ideas?
Old Oct 5, 2025 | 03:46 AM
Does it do it regularly? Does it do it after you have been using it a certain length of time? Can you re-start right away, or need to let it stand for a while? Usual suspects are tank vent blocked, a sucking sound if you open the cap when the fault is on, indicates this. Over rich mixture, indicated by a sooty plug, check after a run. Or an ignition fault, try another plug first but usually trigger or power coil failing when hot. Carry a spare plug, when fault comes on, whip cap off and try for a spark with spare plug against head while fault is on.
Old Oct 5, 2025 | 06:58 AM
HondaMan71's Avatar
Default Reply to shut down
This happened on a ride a few weeks ago. Several day before the ride, I changed the spark plug just as normal maintenance. During the ride the shutdown occurred 3 times, all while traveling approx. 40 mph. The atv would start back up after waiting 2 or 3 minutes with no problem. I am not sure if it showed a fault as my son was driving it. Thanks for your response!
Old Oct 6, 2025 | 02:53 AM
Try another plug, new does not always mean good. 40mph on a Recon must be close to flat out, it is possible he seized it. They quite often run after they cool a bit but you usually get a lot of piston slap and compression will drop.
tompeter
Mar 31, 2024 02:23 AM
Hitting_Bombs19
Nov 24, 2023 03:08 AM
tateoliver
STOLEN
Jan 16, 2023 03:48 PM
Kraig9940
Jan 16, 2001 07:04 PM
